What OS should I use. at DVinfo.net
Old November 2nd, 2006, 08:55 PM   #1
I've just finish buying parts for a new computer, it's built around the Intel Core 2 Duo 2.1 ghz processor. I was just going to install in it Windows Xp professional with SP 2 until someonte told me that I should install Windows 64-Bit edition to really use the whole processing power. Is this true? If this is true, should I buy again all my applications (lightwave 3D, Premiere, After Effects) to be compatible with the 64 bits version?
www.8cho.com.mx
Rodrigo Gil Medina is offline   Reply With Quote
Old November 3rd, 2006, 10:49 AM   #2
I don't believe 64-bit versions of Adobe software exist.
People who have tried Premiere on a 64-bit OS seem to be disappointed:
http://forums.creativecow.net/cgi-bi...868076&pview=t
Adobe have a FAQ here: http://www.adobe.com/jp/products/pre...emiere_faq.pdf which states:
Q: Does Adobe Premiere Pro 2.0 support 64-bit processors?
A: Yes, Adobe Premiere Pro 2.0 works on 64-bit processors. However, it is not optimized for use on them, so you should not expect to see performance improvements.
So, it seems you will use your existing 32-bit versions of Premiere and After Effects. Therefore, you could create a dual-boot system with 32-bit and 64-bit versions of Windows and compare them.
Also, if those applications are available as 64-bit versions, it seems it would be *very* expensive to switch. You'd probably get more value for your money by upgrading your hardware to a much faster processor.
John Miller is offline   Reply
