using still photos in my project
i hope this is the correct forum.
Does anyone have any tips for importing stills into my project im using final cut pro, and i want to use 5 stills. they come out sort of blurry when i zoom in on them. should i deinterlace them, or what size should i use. psd? tif? thanks in advance |
The stills might need to be higher resolution?
2- It's usually best if you monitor on an external A/V device... i.e. a DV camcorder. This will let you spot things you can't see on a computer monitor. If not, the next best thing in this scenario is setting the canvas to 100% zoom. 3- The file format doesn't make too much of a difference, other than if either format doesn't work. Photoshop layers are supported in FCP. |
I believe this article should help with your still image question.
http://larryjordan.biz/articles/lj_grfx_look.html |
