Is my PC up to editing HDV? at DVinfo.net
Old March 23rd, 2006, 05:15 AM   #1
Other than the video card which I know would need adding on (I currently have an X800 256mb card); as well as me purchasing new hard disks to store all the extra info...
Is an AMD 64 3500+ with 1GB Dual Channel RAM enough to edit HDV footage or am I looking at needing to upgrade... if it will edit it just, thats ok for the moment at least till money starts coming in and then I can upgrade.
Cheers in advance
Ben Furfie
Project Manager
AlienPants Ltd
Ben Furfie is offline   Reply With Quote
Old March 23rd, 2006, 06:54 AM   #2
Ok
Hey Ben,
You should be ok with that setup. However I really suggest a couple of things;
1. up your ram before worrying about your video card. 2 Gigs is a good place to start.
2. Purchase Cineform's HD Connect. It will make editing a whole lot more enjoyable. Much better performace, and quality.
Well good luck and have fun.
Darrin McMillan is offline   Reply With Quote
Old March 23rd, 2006, 10:16 AM   #3
The video card should be fine. As Darrin mentioned, upping RAM to 2 gigs would be a very good idea. A dual core processor would probably be the next upgrade that would help the most (by far).
Robert M Wright is offline   Reply With Quote
Old March 23rd, 2006, 03:21 PM   #4
Cheers guys, I believe my brother new PC is a Dual Core Intel Celeron 850... I might have a look at that...
I've heard good things about Cineform but I've been trained pretty much on Premier Pro 2.0. Once we have a little money that we can put to the side I might have a look at it...
Ben Furfie
Project Manager
AlienPants Ltd
Old March 24th, 2006, 08:01 PM   #5
Help with similar question
Hi, I am wondering if you guys can help me out with similar issue. I'd like to edit HDV footage from JVC HD100.
I have an option of buy a
1. Sony VAIO VGC-RB53 Intel Pentium 4 630 3.0GHz (Hyper Threading)
or
2. DELL E510 Dual Core Pentium D processor 2.8mhz
As for the rest of the hardware I pretty much know that I have to have 2GB ram, 7200 rpm hard drives, at least 256 mb video card.
anything else??? thank you very much in advance
Rati Oneli is offline   Reply With Quote
Old March 25th, 2006, 01:42 PM   #6
MPS Digital Studios
Darren is right--try a Proxy editor with Connect HD or try Vegas and combine it with VASST's Gearshift. www.vasst.com
hwm
My Final Cut Pro X blog
Old March 25th, 2006, 04:39 PM   #7
I run a dual core self built AMD 3800+ box with an X700 256 ATI PCI Express Card, 2 gigs of memory. It actually edits native HDV pretty well, but most of the pro will go to Aspect from Cineform for easier and cleaner editing, and better color handling. About $500, as I understand, and runs inside PPro 2.0, and provides real time previews in most of its transitions and effects. It does take up about 5 times the disk space for the same footage. I am sure it is a good investment... I'm just looking for the right time...
Chris J. Barcellos
Old May 26th, 2006, 10:36 PM   #8
what do you capture your HDV with?
Brandon Biodrowski is offline   Reply With Quote
Old May 26th, 2006, 10:52 PM   #9
HDVSplit is a freeware program. Get the .75 version. It captures Native. I can also capture native with the Premiere Pro 2.0, which I edit with, but it does not scene detect like HDVSplit.
Chris J. Barcellos
Old May 30th, 2006, 10:08 AM   #10
If you were running Avid Liquid 7.x, then the answer would be yes.
George Ellis is offline   Reply
