Editing software (PC) for DVCproHD ?
I know i should (?) use Apple video editing platform with my Panasonic HVX-200, but i would like to use PC if possible...
Is the new Adobe Premiere pro 2.0 support DVCpro HD ? i can't find the thread about that in the Hvx200 section... As a newbie, i really want USER-FRIENDLY software. I don't have much time to learn and i lose patience fast when it's not efficient. Any recommendation ? |
#2 | |
#3 | |
Well, is that mean that Apple is THE only real solution for the Panasonic Hvx200 for now ? Let's say i'm all beginning this from scratch.. Will it be a good idea anyway to go (and learn) with apple/Final cut pro platform instead of going with PC/"whatever that will comes out sometime" ? *Apple angel saying "Come with us, we're better!" * |
Edius Broadcast will edit P2 and preserves .mxf file data. If you decide to explore this route it would be advisable to check out minimum specs. The HP XW8200 with dual Xeon processors is said to to the job well.
#5 | |
At 900$ the price seems reasonable. |
#6 |
You will find a lot of information here:
http://www.canopus.com/home.php If you are familiar with Premiere, this site will be useful for making comparisons: http://www.panoramaproductions.net/edius.html This site is by someone who has made the transition and offers his experiences. I do not know enough about other apps to offer a reliable comparison for you. But based on comments made by others Edius, in its current 3.61 version, offers fewer features than other nles - it has been around for a much shorter time. Some do not like the interface - it is different. On the other hand, on the right hardware, it will probably offer more RT performance than most. It also appears to offer better access to the new HDV/HD formats than some other nles. If speed and time saving matter more than compositing then it is worth a look. The Canopus site listed above includes comprehensive product information, on line tutorials on getting started and a route to the Canopus forums which are very helpful. |
#7 |
For PC-based editing of P2 footage, Edius Broadcast sounds like the way to go for now, but you might also take a look at the latest Avid HD solutions. Avid Liquid can reportedly handle DVCPro50 footage fine but not DVCProHD yet. Edius is a little limited in terms of some advanced features but is being successfully used by many people for professional purposes, and is being adopted by some TV stations for its real-time capabilities.
By some accounts Edius Broadcast currently has *the* best support for HD MXF files, e.g. compared to FCP which has to convert them to a Quicktime wrapper before editing. |
#8 |
And regarding the easy-to-learn side (i never touched any video editing software, only photo) should i go with Apple/FCP combo or PC/canopus ?
#9 |
Any advanced video editing application is likely to take some time to learn. Final Cut Pro is probably more standardized than Edius and will have more training options available; Edius has proved easy to learn for some people and hard for others, with limited training solutions.
#10 |
I switched from Premiere 6.5 to Edius at v1. I found Premiere awkward to use (and unreliable) and Edius easier to use and very reliable) - but that is a personal thing. My own experience with Edius is that you can start just doing simple things very easily and work into more complicated things at your own pace. That said there will be a learning hump to get over initially whichever software you go for.
