overcranking from 60i/50i to 24p or 25p at post at DVinfo.net
Old January 19th, 2006, 01:30 AM   #1
Guest
Posts: n/a
Digital overcranking from 60i/50i to 24p or 25p at post, it works but it isn't the same like a native overcranking from a camera system like Panasonic's HVX-200 or the Sony's PDW-F350, right?
I ask: how far it is? Is it possible to get good slowmotion at post? Similar as at the traditional way imported from the film cameras? Or the results will never be the same and at post it will be always noticeable worst?
Old January 19th, 2006, 08:35 PM   #2
Hawaiian Shirt Mogul
you want to take your 60i and have it play back with a frame rate of 24fps ?
if YES .. use after effects ... convert the 60i to 60p ( every field becames a frame) .. then render 23.976 layer using time stretch ( so clip plays back 24fps = takes approx 2 1/2 sec toplay back that 60i )
Don Donatello is offline   Reply With Quote
Old January 19th, 2006, 10:45 PM   #3
Guest
Posts: n/a
And from 50i to 25p?
Is there other solutions? Better ones or After Effects is the best option?
Is it possible to compare to the same results from the Panasonic's HVX-200 or from the Sony's PDW-F350?
Old January 20th, 2006, 10:18 PM   #4
shooting slo motion will always be better then "creating" it ...
AE will do it .. maybe combustion , probably other special effects programs too ... BUT the problem is 50i interlace would change to 50p = each field is changed to a frame = there's only 1/2 the info there to begin with and it isn't going to equal a progressive frame shot on any progressive camera.
there's Twixter that can create NEW frames
http://www.revisionfx.com/rstwixtor.htm
Old January 21st, 2006, 02:18 AM   #5
Guest
Posts: n/a
Thank you Don!
50% of losses?
I figure out but this simulation after 60i/50i -> 60p/50p -> 25p or 24p is it so noticeable to an average audience, comparatively speaking?
What does it mean -- NEW frames? Will it be a better or the best method?
Old April 3rd, 2011, 12:09 AM   #6
Re: overcranking from 60i/50i to 24p or 25p at post
Hi
so what is the best method for making az 50i HDV video to 24p HD?
I think 50i - >deinterlace with good quality method to 25p,
and then simple playback the 25p footage at 24Hz.
I cannot to all this in Vegas, what should i use it?
AE? Or maybe some avisynth script can also do the job?
The most imprtant thing is do this process without any interpolation
between frames! I want the real 25 frames, just play at 24.
(i need this to make a 3DBluray from my 50i source, and that standard is only 24p now)
thanks!
Relaxing clips with waterfalls and music, 3D photos, 3D videos:
www.3d-video.hu
Prech Marton is offline   Reply With Quote
Old April 3rd, 2011, 03:50 AM   #7
Speaking of twixtor Have a look at this it was cranked using it.
Here's a link to the Guy that put this together.
http://michaelblieden.com/?p=619
Last edited by Donald McPherson; April 3rd, 2011 at 03:53 AM. Reason: Added another link
Donald McPherson is offline   Reply With Quote
Old April 8th, 2011, 03:57 AM   #8
JES Deinterlacer will do this job for you, with the understanding that you will drop resolution.
Load the 50i/60i footage and choose a change speed preset.
Home Page of JES
Adrian
http://chillfactorfilms.com
Adrian Frearson is offline   Reply
