HDV and software at DVinfo.net
Old September 29th, 2005, 02:12 PM   #1
HDV and software
I wasn't sure which forum to post this, but I was wondering if HDV work well with the following programs: ParticleIllusion and After Effects. I currently use Vegas, but if I upgrade to HDV, I would use Gearshift. How well would HDV files (or intermediary files) work with these two programs? Thanks.
Robert Kirkpatrick is offline   Reply With Quote
Old September 30th, 2005, 07:02 AM   #2
After effects works with almost any resolution, certainly much higher than HDV.
However it has big problems with MPEG2 compression, so you would have to use an suitable i-frame, or uncompressed codec.
Dylan Pank is offline   Reply With Quote
Old September 30th, 2005, 10:31 AM   #3
When I first got my FX1, I found that I had an MPEG-2 codec that allowed AE to import HDV footage. I don't know where the codec came from, but not all can do this. I found that to do decent effects work, it was well worth it to convert the MPEG-2 data to an uncompressed avi... otherwise workflow would grind to a halt. This took up a lot of hard drive space, but was worth it.
Now that I have AspectHD, I just copy/paste from Premiere into AE, and work on the Cineform files straight up.
-Steve
Steven White is offline   Reply
