HD to SD workflow WITHOUT jagged/wrinkled edges at DVinfo.net
Old November 5th, 2010, 08:27 AM   #1
Using native timeline from beautiful Canon XF300 footage. I export as a Quicktime movie (full HD). Is there a best down-conversion method to SD such that the SD looks decent (that is, doesn't have those weird jagged edges/wrinkled edges with certain shots)?
The color quality is still beautiful (and better than typical SD footage), but the lines are not as good as if I had just started with SD footage.
I guess what I'm asking is: is there a tried and true HD-SD workflow via Final Cut Pro 7, and/or compressor, and or save-to-quicktime that I'm missing?
Event Videography, New England
www.timothybakland.com
Tim Bakland is offline   Reply With Quote
Old November 5th, 2010, 08:33 AM   #2
Yes, and this topic has been covered in depth numerous times. I believe the master thread is located in the FCP area of this forum, but it's been some time since I referenced it.
I believe the answer you seek is in "Frame controls" in Compressor, but I am not an FCP user so I don't remember exactly where everything was.
Old November 5th, 2010, 09:28 AM   #3
Perrone is correct. You can turn on the Frame controls in Compressor to control how the downconversion is done. You can choose how to treat the incoming & outgoing fields and how scaling is done.
I'd recommend that you run some tests using different combinations and save the best result as a droplet.
Arnie Schlissel is offline   Reply With Quote
Old November 6th, 2010, 08:45 AM   #4
Thanks so much, guys.
I hadn't had luck finding the exact thread that worked and "frame controls" was the missing ingredient, indeed.
Thanks again.
