Quicktime h.264 very slow at encoding .....
Greetings,
I need to know what I'm doing wrong. I have use iMovie 09 build [8.0.6] on (4) different Macs ( MBpro 13/15", 27" i7 iMac and mac mini ) All the units are running OSX 10.6.3. I also use Final Cut Express 4.0.1. I shoot sports events with a Canon HDV30 using 30p and import to iMovie. After my footage is cut I end up with ~1hr worth of footage. The problem that I'm having is that is takes a minimum of 24hrs or more to encode (1) event to Quicktime using the following settings. Video:: compression: h.264 Quality: high Key Frame rate: 30 Bitrate: 5,000 kbits/sec Frame reordering: yes Encoding mode: multi-pass Dimensions: 1280x720 (1248x702) Scale: letterbox Sound:: Format: ACC Sample rate: 44.100 kHz Bit rate: 128 kbps This same length of time occurs when i export to FCE or iMovie. I'm trying to achieve high quality HD video for Vimeo. What am I doing wrong? Did something change in Quicktime via a patch or with OSX 10.6.3? Although I'm running Snow Leopard i also installed the legacy Quicktime 7 version. Please help, I'm shooting 5-7 games in a weekend and right now I don't have time to get everything processed do the amount of time a single encode is taking. Any and all help and comments are greatly appreciated. Please review the attachments for additional information. Would I gain anything by using .mp4 vs .mov |
Sounds similar to the encode times I get. H.264 is a pretty high intensity codec to encode, especially when going for quality.
Shaun C. Roemich Road Dog Media - Vancouver, BC - Videographer - Webcaster www.roaddogmedia.ca Blog: http://roaddogmedia.wordpress.com/ |
I agree...sounds a little long to me but on those computers, reasonable. To really bump up the speed, the multi pass option could be turned off.
Have you looked into Matrox MX02 with Max? There's a version for laptops with an express34 slot. Hardware and software bundled and It's much faster at encoding h264. Otherwise, might have to upgrade to a macpro with 8 cores. (still get the MX02 with Max) Mine absolutely rips through h264 encoding using the Matrox codec.
The older I get, the better I was! |
Glad to hear - my next box with be a Pro 8 core with the Matrox encoder and I was HOPING to get those results... as soon as the new Pros come out, that is...
#5 |
Elgato...
Look into the Elgato Turbo H.264 encoder. It's just a USB Dongle that accelerates encoding to H.264 specifically. relatively cheap if you need speed during the encoding process. Only offers single-pass, but as its a hardware solution the quality is pretty good.
Is there any specific reason that you have "Frame reordering" on? |
#6 |
Jonathan.....
I've noticed that you've got filtering enabled....Get rid of it. It will destroy your times..You're better off filtering in post, and let the encoder do it's job.. Also, if time is a problem, use VBR 1 pass... Good luck!!! |
#7 |
Jonathan, have you looked into Handbrake yet? It's available for both Mac and PC and it is using the x264 codec (compatible with h264).
Lightening fast on my i7/920 PC. Can encode an hour of HD video faster than real time, settings depending. |
#8 | |
