December 2nd, 2009, 04:56 AM | #1 |
TV Output
Hi,
I have been using Canopus and Premiere 1.5 for my video editing but since the high definition I had to buy a new computer and using Premiere CS4. My problem is that now since my Canopus card is not compatibale with Premirer Pro 4 I do not have a TV output any more, before I use the get the TV output from my Canpous card to my TV so I could see my work live while edditng. How can I do it now without buying another third party video editing card? Waht is the cheapest and easiest solution please? Many thanks in advance Mitchell |
December 2nd, 2009, 05:22 AM | #2 |
Mitchell,
Use firewire out to your camera or deck and use analog out from the camera to the TV. |
December 2nd, 2009, 06:45 AM | #3 |
Harm,
Thank you for your reply, this is okay to use once t otwice but not for me as I am editing full time, it will be very hard for me to have my camera connected constantly. I am looking for a cheaper solutions. Regards Mitchell |
December 2nd, 2009, 07:46 AM | #4 |
It doesn't come any cheaper than this. You have the firewire cable, you have the camera and you have the TV. No investments.
December 4th, 2009, 05:19 AM | #5 |
Thank you for your idea, but it is not possible for me to have my camera connected to my computer 10 hours a day, so I need another alternative.
Perhaps soem sort of card. Any idea please, what is every one else doing without a third party catputre card? Thanks Mitchell Last edited by Mitchell Yazdani; December 4th, 2009 at 06:43 AM. |
December 9th, 2009, 05:26 AM | #6 | |
Thank you for your answer, I did try that, I connected the camera t othe computer and from analog to my TV, but I get blck screen on the TV! How do I set up the Premiere CS4 to output to my camera? Thanks Mitchell |
December 9th, 2009, 08:37 AM | #7 |
I am not sure if I understood correctly, but if you want to work your preview window in an external TV set, then Premiere supports that natively and without extra hardware. What is needed is a connetion through graphic card's secondary DVI or VGA or HDMI output to the TV, let the system drivers know that you have two monitors in extended desktop mode, and then go to Premiere. Create a new project, go to custom settings/Playback settings and select your secondary monitor (that means the TV). From now on (in this project only) you will have preview in your TV. Note that you can't alter those project settings once you have created it (don't ask me why :) ). You have to do it when creating the project, or you can insert an existing project into a new project with the correct settings. That is what I do, no extra equipment needed, and it works fine with both ATI and Nvidia cards. I haven't tried yet with a CRT TV through s-video, but I've heard that it works all the same.
"A successful wedding videographer is the one that offers for viewing some excellent videos and some boring videos, and gets positive reviews for both". |
