Quick After Effects question at DVinfo.net
Old November 17th, 2009, 09:54 PM   #1
I am using the RemoveGrain tool. When you use this tool it shows you a "preview region" which represents the final output. This region is shown in a white outline, 200x200px by default. The problem I am having is when I export the clip, it is showing the outline in the middle of my frame! And the grain is only removed from the preview area, even AFTER I export! This ever happen to you? So frustrating...I have used the tool before without this problem.
PC, CS3, Core 2 Duo
JS
John Stakes is offline   Reply With Quote
Old November 17th, 2009, 11:52 PM   #2
Just gave it a try, sending clip to render queue, then make movie to a default avi, got the same result as you. Must be a new bug. I tried linking to a Premiere sequence, it's taking so long I think it's not going to do it at all, so unable at this time to see if the box shows up in Premiere. It is definitely in the avi that was created...bummer...../Battle Vaughan
UPdate: if you click on the FInal Output choice instead of Preview choice in the effects controls window, the box goes away...
Old November 18th, 2009, 03:11 AM   #3
Battle thankyou for the reply. I JUST shut my system down, ended up editing & completing a different project. I will get back into AE tomorrow (well in a few hours) and try again.
JS
Old November 20th, 2009, 01:57 PM   #4
Thanks again Battle. That did it.
JS
