Frame Rate Confusion - Keeping native 60i
I am working on a workflow for a FX1 to a soon to be purchased HDTV with the same resolution.
Ideally I would like to use Premiere 1.51 to do basic editting, AFX only for compositing or fine tuning if needed, then render either to WMV or HDV on tape or SD depending. I have an AveLink so it has been WMV, but now we are buying a HDTV so I want to export HDV back to tape for the FX1 as we will be plugging this into various HDTVs My concern is with frame rate. When exporting HDV from the FX1 to PPro 1.51, the closest option to 60i is the Aspect HD 1440x1080 30i setting (which I have been told is the same as 60i). When I look at the project settings however, even the clip properties I see that they all basically say they are 29.97 fps. But I want 60i! How can I get native HDV with correct resolution out of PRemier? I currently have copy pasted the 30i video from PRemier into a AFX Comp with 59.94 to be rendered to AVI to plug back into PPRO but then in PPRO this would be going to the same 30i project, so its a little redundant... I want to keep the highest possible color space and resolution, for a 1080 HDTV. I am already concerned about the anamorphic scaling in PRemiere as there is no 1920 x 1080 option available. And does it even have to be interlaced or should I make it progressive? This is the last of my worries, (funny its the native part) while I have worked out all the other compressions and outputs (WMV and SD). Great thread I have followed, but the workflow Steve White suggests is a little confusing: http://www.dvinfo.net/conf/showthread.php?t=45165 Any help is appreciated! Brooks |
#2 | |
Native 60i
Thanks for the reply,
I understand that 60i is 29.97. I found that I can create a project in PRemier that has a 60 fps or 59.94 fps timebase. When working with 60i footage should I be in 60 or 59.94 fps timebase? or keep this 29.97 fps as televisions in NTSC are usually this fps. It gets a little confusing. Almost there! Brooks |
CTO, CineForm Inc.
CineForm tries to refer to frames per second not field per second. This way 30i vs 30p actually makes sense. In this terminology there is no 60i, yet there is a 60p. 30i (or your 60i) has a 29.97 timebase to be correct. Naming aside, 30i is the standard 1080 HD interlaced frame rate that complies with all expected standards.
David Newman -- web: www.gopro.com blog: cineform.blogspot.com -- twitter: twitter.com/David_Newman |
