PAL / NTSC conversions for High Def content at DVinfo.net
Old September 22nd, 2009, 06:43 AM   #1
Equal Opportunity Offender
I haven't had to deal with this yet, but I'm keen to know what others have done to convert between the standards when it comes to high definition footage.
Your thoughts?
Andrew
Old September 22nd, 2009, 03:11 PM   #2
Andrew,
check this thread:
http://www.dvinfo.net/forum/cineform...-ntsc-pal.html
Best
Vasco
www.donesmedia.net
bricioledamerica.blogspot.com (in Italian)
Vasco Dones is offline   Reply With Quote
Old September 23rd, 2009, 01:54 AM   #3
Took a look through all that. Seems like it was all for standard def output in the end, though sometimes from a HD source.
What I'm wanting to do is to convert from HD to HD.
Andrew
Old September 24th, 2009, 11:45 AM   #4
Andrew,
in that older thread,
just skip the downsizing-related sections.
Basically, you can try Atlantis, Procoder, TMPGenc,
or go the AE route.
Best
Vasco
www.donesmedia.net
Old September 24th, 2009, 07:21 PM   #5
Hi Vasco,
I'm an Atlantis owner and it only does standard def conversions. I've posted on the forum there and (unless something has happened in the last year) I don't think Marcus is too interested in creating a version for HD work.
After Effects I'd prefer to avoid as the built in de-interlacers cut vertical resolution by 50%. See "Is it better than converting with Premiere or After Effects?" at the DVFilm Atlantis web site
ProCoder's web site shows that their product will read and write to HD formats as well as doing the standards conversion. I'd feel a bit safer if they explicitly stated that their product will do standards conversions for HD content.
I've looked on the TMPGenc site and don't see anything about standards conversion. Might be a script that needs to be run. (I also might need to run some tests with the software to see if the conversions are effective).
On the positive side, I haven't come up against a job where I have needed to do this ... yet. I'd be keen to know what to do ahead of time, though.
Thanks for the help thus far.
Andrew
Old September 25th, 2009, 11:14 AM   #6
Just to update the issue. I have received the following in a reply from the DVFilm people.
Atlantis for Windows supports HD resolution video. As of now, Atlantis for Mac does not support HD Resolution video, but there are plans to add it in the future though there is not a timetable, yet.
So that's fantastic news for me as I already have their software. It was a chunk of money to purchase it, but consistently well worth it.
Hope this is of help to some of the others here.
Andrew
Old September 25th, 2009, 05:07 PM   #7
(it was stated in the above-mentioned thread, though...)
www.donesmedia.net
Old September 25th, 2009, 07:37 PM   #8
[bows to the mighty fount of knowledge known as 'Vasco']
