converting an HDTV .m2t file to HDV for iMovie HD edit at DVinfo.net
Old January 19th, 2005, 09:43 PM   #1
Hello,
I ordinarily participate on the avsforum regarding HDTV recording on the Mac. Someone has tried to edit a .m2t file that was captured from a local HDTV station using the new iMovie HD. Apparently, iMovie HD is looking for a true HDV.m2t file. The attempt failed as iMovie HD would not recognize the file.
So, is there any way to convert an over-the-air ATSC HDTV .m2t file to an HDV .m2t file for the purpose of editing the file in iMovie HD?
Joe
Joe Betsko is offline   Reply With Quote
Old January 20th, 2005, 09:53 AM   #2
I suggest trying SQUARED 5's MPEG StreamClip (free)
While I have not tried mt2 -> m2t using the utility you should be able to convert from m2t to Quicktime whiche can be brought into iMovie.
http://www.alfanet.it/squared5/mpegstreamclip.html
Paul St. Denis is offline   Reply With Quote
Old January 20th, 2005, 10:12 AM   #3
Does this mean that iMovie-HD deals with native HDV rather than using the AppleIntermediateCodec that FCE-HD reputed uses, or with it convert the mt2 to the A-I-C when importing?
Dylan Pank is offline   Reply
