HDV JVC DH30000U deck computer install help at DVinfo.net
Old May 29th, 2004, 11:06 AM   #1
I have the DH30000U D-vhs deck and I am planning to use it with my firewire card on my computer, along with my hd10u. I noticed when I pluged the firewire cable into the deck from the computer the plug-and-play installation stops at hardware wizard looking for av/c tuner. Does this unit not install and can it not be controlled by a computer. If it can then am I missing a driver or some other software. I have a athlon64 using widows xp home. HELP.
Dwight Flynn is offline   Reply With Quote
Old May 30th, 2004, 10:51 AM   #2
MPS Digital Studios
This might be an editing question, Dwight. Want me to move it over there?
heath
My Final Cut Pro X blog
Old May 30th, 2004, 12:01 PM   #3
CTO, CineForm Inc.
You do not need the AV/C Tuner driver. It isn't included with XP or with any of the JVC software. Simply cancel that install when it askes for the Tuner driver.
Old May 31st, 2004, 07:28 AM   #4
Thank David and Heath for the move and helpful reply. I will give it a try.
Old June 3rd, 2004, 08:51 PM   #5
Found it DH30000U computer connect
Hey Heath, (and all the other folks) I found this handy link that explains how to connect the JVC HD30000U d-vhs deck to a computer (it should also work for the 40000u). I am going to try it tomorrow and let you know the results.
http://www.webtc.com/DVHS/default.htm
Dwight
Old June 4th, 2004, 12:14 AM   #6
MPS Digital Studios
For Mac, Lumiere HD does the trick.
hwm
