May 26th, 2004, 06:18 AM | #1 |
panasonic HD firewire deck.
How can you use this deck to capture and edit HD through firewire? you need special capture cards to capture 10-bit uncompressed digibeta, so how can you capture HD since it has a bigger color space and has an even higher bit rate?
May 26th, 2004, 11:14 AM | #2 |
MPS Digital Studios
What's the model number of the deck?
heath
My Final Cut Pro X blog |
May 26th, 2004, 11:34 AM | #3 |
Editing in Final Cut Pro HD is suppoerted natively over firewire. Here's a link that has some technical info:
http://www.apple.com/finalcutpro/codecs.html Panasonic's link is: http://www.panasonic.com/business/provideo/nab_access_hd.asp |
May 26th, 2004, 11:46 AM | #4 |
MPS Digital Studios
Mike,
To make clickable links, do this: [url ]www.dvinfo.net/conf[/url ] Just take away the space between the two "l's" and "]" heath
May 26th, 2004, 12:55 PM | #5 |
the model numer to the deck is AJ-HD1200A
