Sony M35U aspect ration record problem at DVinfo.net
Old June 17th, 2009, 10:16 PM   #1
Dear technical wizards,
We recently purchased the Sony M35U HDV deck. At the moment, we're feeding a 16x9 DVCAM signal into the deck from Premiere Pro via firewire. The deck is reading the signal as 4x3. We've been going over the menus but can't find a solution.
If we play a 16x9 DVCAM tape, it plays 16x9.
Any ideas, thoughts or possible solutions?
Thank you very much in advance,
Joe
Joe Yaggi
Creative Supervisor, Director, DP www.jungle-run.com
Joe Yaggi is offline   Reply With Quote
Old June 19th, 2009, 03:07 AM   #2
If you record that DVCAM 16x9 signal to tape and then playback is the image 4x3 or 16x9?
-A
Andrew Kimery is offline   Reply With Quote
Old June 21st, 2009, 05:26 PM   #3
Equal Opportunity Offender
Hi Joe,
I've got the M25 model of this deck.
Is it the LCD video monitor/screen on the front of the deck that you are judging by? I've noticed that whenever I have SD video passing through the deck, it is displayed as 4:3 aspect ratio (regardless of whether it is 4:3 or 16:9) on this screen. High Def content is always displayed at 16:9, making use of the full width of the display screen.
I think it's just what this deck does with monitoring incoming external video.
I have noticed (now that I think of it) that 16:9 SD content shot with my V1 displays using the full width of the LCD screen when playing back from the tape.
Andrew
