Post HD Stablization at DVinfo.net
Old June 11th, 2009, 10:41 AM   #1
We shot a band the other evening and I have one camera fixed on sticks for the safety wide shot, the problem is the venue was old and had all wooden plank flooring so with every bass note and kick drum hit I got a vibration the camera/video throughout the whole hour of footage.
Any decent recomendation on the most effective post correction software solution.
I had a friend try and run it through Mercalli's without much success, any recomendations would be appreciated.
Thanks in advance.
Curtis Edwards is offline   Reply With Quote
Old June 11th, 2009, 11:46 AM   #2
VirtualDub + deshaker plugin
And don't be confused by it's freeware nature.
Javier Gallen is offline   Reply With Quote
Old June 11th, 2009, 11:55 AM   #3
Thanks, great I will check it out, is it pretty straight forward in the use and implementation?
Old June 11th, 2009, 12:13 PM   #4
It's not way to difficult to figure out, but it can be very slow. A high power CPU is your friend.
Robert M Wright is offline   Reply With Quote
Old June 11th, 2009, 12:25 PM   #5
No rush on the project so time is not a problem and I have a fairly capable machine. I will check it out tonight. Thanks again for the guideance!
Old July 30th, 2009, 02:25 AM   #6
mercalli
i use mercalli from PRO DAD.ità plugin for premiere and others.it works great.
Willkomen auf Plotzer.at
fred from austria
Alfred Plotzer is offline   Reply With Quote
Old July 30th, 2009, 08:15 AM   #7
"I had a friend try and run it through Mercalli's without much success, any recomendations would be appreciated."
"it works great." Obviously not for the OP.
Old July 30th, 2009, 09:58 AM   #8
To get good results from Mercalli, you need to select the appropriate preset - it is by no means always the obvious one!
If you are using Prmiere, you need to be careful to ensure that Mercalli uses the correct field order. With Premiere CS4, you need to be using CS4.1, and the latest Mercalli update for good results
Alan Craven is offline   Reply With Quote
Old July 30th, 2009, 11:12 AM   #9
Thanks for all the feedback it's appreciated
Old August 1st, 2009, 05:58 AM   #10
You can do a lot more with SynthEyes SynthEyes Camera Tracker - Andersson Technologies LLC than Mercalli. You can dial in or out the frequency of vibration.
If the vibration is causing motion blur from a slow shutter speed then you are in trouble.
Mercalli with the right preset works pretty good though.
Cheers Ian
Ian Newland is offline   Reply With Quote
Old August 1st, 2009, 10:10 AM   #11
Virtual + Deshaker has worked wonders for me...
Perrone Ford is offline   Reply
