Pre-compression HD from analog component outputs?
I've read people posting on another forum that the HD1OU puts out pre-compression HD from the analog component outputs.
Can anyone confirm if this is true or not please?, it would be great, but it seems a bit too good to be true to me. Anyone out there know for sure? Thanks
Paul |
CTO, CineForm Inc.
It very likely to be pre-compression, but the signal out of the analog component connector while shooting is only 480p, even in the 720p mode. I don't know why, but it puts a damper on some neat ideas.
David Newman -- web: www.gopro.com blog: cineform.blogspot.com -- twitter: twitter.com/David_Newman |
Thanks David, that's what I thought, not much good if it's only 480p, even if it is pre-compression. I don't know why they're getting so excited about capturing it via a Kona card if it's only 480p unless you're only working with SD, oh well.
Paul |
Steve Mullen's original review from the camera says that you can output 720p from component
"A YPbPr cable supplies analog component output for all recording formats. You can choose to output 480i/480p/720p" Video Systems,_Feb 1, 2003 Where have you seen that it will not output 720p when recording? |
#5 |
CTO, CineForm Inc.
<<<-- Originally posted by Paul St. Denis : Steve Mullen's original review from the camera says that you can output 720p from component
"A YPbPr cable supplies analog component output for all recording formats. You can choose to output 480i/480p/720p" Video Systems,_Feb 1, 2003 Were have you seen that it will not output 720p when recording? -->>> I know both from experience and from JVC staff. The menu is only available via playback, and then yes in playback you get 720p, but not while capturing. There is no way to get uncompressed 720p from this camera. However the need for an uncompressed feed from the camera is not as great in the DV world. In DV 4:1:1 happens at the compression stage, there is more color information pre-compression. In the JVC camera the 4:2:0 is inherent in the CCD architecture, therefore you are not lossing color resolution. MPEG2 compression artifacts are of course are present, but are they not significant and anything unwanted can be cleaned up in post.
#6 |
Thanks David,
A few things are still confusing to me though. I have a YPbPr menu item while recording which gives me the option of outputing 720p. When I change the output to 420i in the monitor I get pillar boxing on a 16:9 monitor, but not for 720p (not for 420p either), shouldn't the output be 4:3 for 420p? The image does not appear to be stretched. |
#7 |
CTO, CineForm Inc.
Yes the menu exists in record mode, but it simply doesn't function as one would hope.
