Latest word on editing HD? at DVinfo.net
Old November 3rd, 2003, 10:03 PM   #1
What is the latest word on editing HD Mpeg2 video? Can HD footage from the HD10 be edited (on PC) and put back to HD (and DVD) easily, cheaply and look great?
I've seen a bunch of posts on this, but they deal with specific programs on different platforms, and outline problems of editing in HD. What is the latest word and products (for PC)? Can ya do it reasonably well/cheap? Best way? Future products? Thanks in advance, I appreciate your help.
Mark G
Mark Goodsell
Mark Goodsell is offline   Reply With Quote
Old November 3rd, 2003, 10:43 PM   #2
MPS Digital Studios
Every solution via Apple so far sounds shakey, complicated, time DEficient and not good if you have a deadline.
APPLE, HELP!
heath
My Final Cut Pro X blog
Old November 3rd, 2003, 11:57 PM   #3
The Vegas solution seems to be the direction. But you may need to solve the problem to convert the mpg file to ts file unless you pay for some softwares to do the job. These softwares includes MPEGCarver Premium and Manzanita. Womble fails in this regards although someone claims it to be OK.
Peter Robert is offline   Reply With Quote
Old November 4th, 2003, 05:29 PM   #4
Depends what you consider cheap. We are trying out aspect and premiere for about $2K...definitely seems like a much smoother operation than that of apple and FCP at least for now.
Lisa Lee is offline   Reply With Quote
Old November 5th, 2003, 02:48 PM   #5
aspect set up time?
Lisa,
I just ordered Aspect... How long did it take you to be up and running editing HD? Is there a lot of set up time, learning curve?
What are the transitions like? Can I use chroma key with aspect?
Thanks in advance.
E.
Erik Rangel
www.inthemind.com
Erik Rangel is offline   Reply With Quote
Old November 5th, 2003, 05:18 PM   #6
No its actually fairly easy. Though I still can't get it printed to tape. I'm sure in future versions of their software it will be all worked out. Let me know if you have problems printing to tape.
Old November 5th, 2003, 06:45 PM   #7
AJA Video Systems
Output to tape
Lisa,
If you are having problems outputting to tape, please contact me or check out our website. I really want to be sure that your product is working the way it should. If you export using Adobe Mpeg Encoder and follow the instructions outlined on our website, you should have no problem outputting the video back to your HDV cam or DVHS deck. Please contact me if you are still having trouble.
thuston@cineform.com
or submit a trouble ticket at our support website
www.cineform.com/support
TH
www.aja.com
Thad Huston is offline   Reply With Quote
Old November 5th, 2003, 07:21 PM   #8
Thanks Lisa.
Thad,
Chroma key in aspect... in pro version maybe?
E.
Erik Rangel
www.inthemind.com
Old November 5th, 2003, 07:41 PM   #9
AJA Video Systems
Erik
Chroma Key is not real-time in Aspect HD. That doesn't mean you cant do it. You just cant do it in Real-Time.
TH
www.aja.com
Old November 6th, 2003, 12:05 AM   #10
I played around with chroma key in Vegas tonight and it was able to do it semi realtime, how ever it dropped some frames in the RT render. But it worked.
Mike
http://www.acdnow.com
Mike Eby is offline   Reply With Quote
Old November 6th, 2003, 10:06 PM   #11
Can someone please explain what's so difficult about putting edited video back to mpeg2? I don't see the challenge.
BTW, I'm a PC user.
Mark Goodsell
Old November 6th, 2003, 10:22 PM   #12
Mark, Premiere Pro has a bug that prevent you from outputting a correctly encoded mpg out of PPro's timeline.
Workaround is to output in uncompressed AVI, then use TMPGENC or other mpg encoder to convert.
Premiere 6.5 doesn't exhibit such problem as it utilizes a great MainConcept's MPEG2 encoder as plug-in.
It may be possible to frameserve the video from Premiere Pro directly into either TMPGENC or a standalone MainConcept's MPEG2 encoder using Avisynth.
But being PPro buggy as it is, I wouldn't anicipate smooth frameserving...
Alex Raskin is offline   Reply With Quote
Old November 6th, 2003, 10:43 PM   #13
MPS Digital Studios
If only those nice edit solutions were in Final Cut Pro. Dang it Apple!
heath
Old November 7th, 2003, 09:56 PM   #14
What about Vegas? How much does the TMPGENC encoder cost? Or is it freeware? Thanks
Mark Goodsell
