Is (and where is) the DVHS capture utility in Panther? at DVinfo.net
Old November 2nd, 2003, 11:10 AM   #1
MPS Digital Studios
In another thread, someone mentioned that Panther may have come with the DVHS Capture Utility? I tried a search for it in Panther, but no luck.
Any clues?
heath
My Final Cut Pro X blog
Old November 3rd, 2003, 09:44 PM   #2
Heath, Panther comes with the firewire drivers for those utilities, I think it does not come with them (virtual DVHS and DVHScap) though. I have not yet received my DP G5 so I have not yet tried Panther but my guess is they are not included. You can find them in firewire SDK18 from the Apple's develloper site.
Eric Bilodeau
video SFX,DOP
___________________
http://www.fictis.net
info@fictis.net
Eric Bilodeau is offline   Reply With Quote
Old November 3rd, 2003, 09:46 PM   #3
Heath, I downloaded and installed Firewire SDK 18 this morning on my dual G5 and captured from DVHScap just fine.
All the best
Paul
Paul Mogg is offline   Reply With Quote
Old November 3rd, 2003, 09:57 PM   #4
MPS Digital Studios
<<<-- Originally posted by Paul Mogg : Heath, I downloaded and installed Firewire SDK 18 this morning on my dual G5 and captured from DVHScap just fine.
All the best -->>>
Downloaded it, installed it, but...WHERE is it? What's it called, so when I do a search, I'll find it and put it in my Applications folder.
heath
Old November 3rd, 2003, 10:00 PM   #5
It is located on your main drive, in this path: Developper/FirewireSDK18/Applications
Unless it appears elsewhere in Panther...
Eric Bilodeau
video SFX,DOP
___________________
info@fictis.net
Old November 3rd, 2003, 10:08 PM   #6
MPS Digital Studios
<<<-- Originally posted by Eric Bilodeau : It is located on your main drive, in this path: Developper/FirewireSDK18/Applications
Unless it appears elsewhere in Panther... -->>>
I couldn't find it in Panther...
What I need to know is, what's the application's name? Is this it:
DVHSCap.pbproj
Otherwise, I can't seem to find the actual application.
I'm dumb, yes.
heath
Old November 3rd, 2003, 10:15 PM   #7
I suggest you use virtualDVHS instead of DVHSCap (witch is DVHSCap.app by the way, DVHSCap.pbproj is a folder, maybe you are not doing your search right). The reason why you should use virtualDVHS is because of it's batch output capabilities.
Eric Bilodeau
video SFX,DOP
___________________
info@fictis.net
Old November 3rd, 2003, 10:19 PM   #8
By the way, DVHSCap.pbproj is located in this path: //Developper/FirewireSDK18/Examples/DVHSCap/DVHSCap.pbproj
Follow the path backwards to find the app in this path: //Developper/FirewireSDK18/Applications
It really should not be complicated
Eric Bilodeau
video SFX,DOP
___________________
info@fictis.net
Old November 3rd, 2003, 10:24 PM   #9
MPS Digital Studios
<<<-- Originally posted by Eric Bilodeau : By the way, DVHSCap.pbproj is located in this path: //Developper/FirewireSDK18/Examples/DVHSCap/DVHSCap.pbproj
It really should not be complicated -->>>
I figured it out: the DVHS Cap was coming up looking very similar to a AppleWorks file, and I thought it was another document. I did a search on the name and opened it. Bingo.
Why do you recommend one over the other? Are they both the same, with the exception of what you described?
Old November 3rd, 2003, 10:27 PM   #10
VirtualDVHS as the option to loop a selected TS file out to tape/DVHS or to batch send all the TS files from a specific disk or folder, this is pretty handy. For the rest they are pretty close to one another
Eric Bilodeau
video SFX,DOP
___________________
info@fictis.net
Old November 3rd, 2003, 10:35 PM   #11
MPS Digital Studios
Thanks Eric. I feel dumb for not finding it earlier, but like I said, the DVHS Cap icon looked like an AppleWorks document.
Ah, well...Back to reading the fun post about HDVCinema...
heath
