Opinions appreciated... computer build at DVinfo.net
Old January 28th, 2009, 11:55 PM   #1
I'm certainly not a computer designer, but this is what seems to me to be a solution for HD video editing. Intended purpose is for creating documentaries and infomercials from a lot of raw HD video. I had another thread regarding what to consider and received some great advice on it--thank you for those who contributed. I'd like to be as sure as possible that this is a good fit and that I'm not designing in a problem by overlooking something. Any opinions would be welcome, including on price. Also would it be unwise to attempt to build it myself although I've never built any computers before. Best regards, Bruce
CUSTOM WORKSTATION, Quad-Core Core™ i7
COOLERMASTER, HAF 932 (RC-932-KKN1-GP) Black Tower Case, EATX, No PSU, Steel
THERMALTAKE, Toughpower, 80 PLUS®, 850W Power Supply w/ Modularized Cable Management, 24-pin ATX12V EPS12V, Quad +12V, Quad SLI Approved
GIGABYTE, GA-EX58-UD5, LGA1366, Intel® X58, 6400 MT/s QPI, DDR3-2000MHz 24GB /6, PCIe x16 SLI CF /3, SATA 3 Gb/s RAID 5 /10, HDA, GbLAN /2, FW /3, ATX, Retail
INTEL, Core™ i7-920 Quad-Core 2.66GHz, LGA1366, 6400 MT/s QPI, 8MB L3 Cache, 45nm, 130W, EM64T EIST VT XD, Retail
KINGSTON, 12GB (6 x 2GB) ValueRAM PC3-8500 DDR3 1066MHz CL7 (7-7-7) 1.5V SDRAM DIMM, Non-ECC
eVGA, GeForce GTX 280, GTX 280 602MHz, 1GB GDDR3 2214MHz, PCIe x16 SLI, DVI /2, HDTV Out, Retail
WESTERN DIGITAL, 150GB (WD1500HLFS) WD VelociRaptor™, SATA 3 Gb/s, 10000 RPM, 16MB cache
WESTERN DIGITAL, 500GB WD Caviar® Black™ (WD5001AALS), SATA 3 Gb/s, 7200 RPM, 32MB Cache
RAID, RAID 0 (striping), min 2 hard drives required
3WARE, 9650SE-4LPML SATA II RAID Controller, 4 ports, Levels 0/1/10/5, 256MB DDR2 cache, PCIe x4, Full-height/Low-profile, Retail
SAMSUNG, Super-WriteMaster™ SH-S223 Black 22x DVD±R/RW Dual-Layer Burner, SATA, w/ Software, OEM
MICROSOFT, Digital Media Keyboard 3000, Keybiard, Black, USB, Retail
LOGITECH, SBF-96 Optical Mouse 400dpi, Black, PS/2, OEM
MICROSOFT, Windows Vista Home Premium 64-bit Edition w/ SP1, OEM
If assembled & Tested by a builder would be about $2900 with a warranty, Standard Service (3 Years Limited Parts, Lifetime Labor Warranty)
Bruce Hedge is offline   Reply With Quote
Old January 29th, 2009, 02:21 AM   #2
Bruce, this is very similar to the computer I just built, except that I have the EVGA motherboard and opted for a nVidia Quatro FX3700 video card. I've been very impressed with the Intel i7 processor.
The only things I see missing, and you might already have thses, would be speakers and monitors.
For me putting together the PC was easy, but I've been around them for many years. There are a lot of little screws and small connectors. If you choose to build it yourself, I would recommend reading all of the product documentation once over before starting to put things together. I tend to add the processor, heat sink, and memory to the motherboard before installing in the case. Then I install the power supply, video card, and motherboard in the case. At this point you should be able to get to the BIOS screen and verify everything is working. I then add in the hard drives,. DVD burners, etc.
Installing Vista is pretty straight forward. Be sure to install the drivers for your motherboard and RAID.
Hope this helps, feel free to ping me if you run into problems.
Roger
Roger Wilson is offline   Reply With Quote
Old January 29th, 2009, 11:10 AM   #3
Thanks, Might ping u latr, gonna bld it myslf. Regards
Thanks again. Confirmation helps on something new. I think I'm going to build it myself after I get my office moved and that should be by Feb 15. Best regards, Bruce Hedge, Boise
Roger
Old January 29th, 2009, 12:15 PM   #4
I would also go with EVGA board, just personal preference. ASUS makes great boards too but I haven't been around since the Core 2 Duo era. If you build it yourself, be sure to get some anti-static wristbands.
JS
John Stakes is offline   Reply With Quote
Old March 9th, 2009, 12:26 PM   #5
That should be quite the monster system. I've been a system builder for 10+ years (PCs, workstations, rack mountable servers, etc) so I'd be happy to take a look and help out (if you haven't already built this system that is) on the build if you wanted another set of eyes.
Don't discount the importance of your case. Coolermaster has some good products but you should make sure your cables can reach where the HDD racks are. Some times the SATA headers are at the bottom, and the HDD racks are above the PSU, which means you might need non-stock SATA cables just to reach up there.
For that many HDDs, good airflow will be crucial to help keep things stable. I didn't check to see if the case used 120mm fans, but the bigger the fan, the quieter it will be.
Also, you didn't mention in this post what NLE you will be working with. If using a NLE that supports offloading of color processing to the GPU, then your 1GB ram car will be able to help out. If using a purely software based NLE, then consider saving money on the GPU and putting it towards nice displays (or just ... saving the money!).
Good luck with the build and give me a ring if you want any second opinions.
Jason Robinson is offline   Reply
