Cutting clips without rendering at DVinfo.net
Old January 18th, 2009, 12:14 PM   #1
Hi all,
I shoot a lot of footage each week that is turned into video files for the web. Months later these same files are turned into blu-ray's and regular DVD's. So I have to keep the orriginal captured footage until they are burned to disk. I use a tapeless system. One of the cameras is not easily accessible during taping so I get a whole lot of garbage footage that I will never use. Out of 30 minutes I might only keep 10 minutes.
Is there a program that can cut these M2T files without rendering? I would like to chop everything off before and after the good stuff and resave the file.
Thanks.
Jeff Coleman is offline   Reply With Quote
Old January 20th, 2009, 07:12 AM   #2
Cant you do this in your Capture software (ie Priemere pro) by using a batch capture setting the in and out points. This way only what you designate as start and stop points are captured. You do a rough cut setting the points then a batch capture. If its a lot f footage you go take a nap or something and the batch capture occurs.
Howard Churgin is offline   Reply With Quote
Old January 20th, 2009, 09:42 AM   #3
MPEG Streamclip can find the keyframe, you set in/out points at key frames and save only the desired part. Absolutely no re-encoding.
Ervin Farkas
www.AtlantaLegalVideo.com
Old January 24th, 2009, 03:45 PM   #4
Thanks Ervin, I just downloaded MPEG streamclip. Sounds like it is exactly what I needed.
