#16 | |
Re: Capture using Premiere, transfer to FCP? Workflow?
I asked a similar question here: http://www.dvinfo.net/forum/adobe-cr...ml#post1587244 I really like the BlueRay suggestion... It's not HDV, but the quality is archival and it could be used for future projects. In terms of HDV output, I have heard that if you are on a PC, you can print to tape with the camera unplugged and it will generate an HDV file on your HDD. Here's one explanation: http://www.dvinfo.net/forum/adobe-cr...ile-trick.html But, last time I researched this, I think the above technique only works on a Windows machine? Can anyone confirm this? This has been my only gripe with Premiere... I really wish they had the same export options as FCP (the export as source, or whatever it is called in FCP... That option is so nice!) Hope that helps! Cheers, Micky
Home: See "Work" :) Work: Canon XH A1, CS3/CS4/CS5/Final Cut Studio/Final Cut Express/Premiere Elements |
#17 |
Thanks for the reply Micky!
www.boostedfilms.com?r=DVinfosig |
