Definitive answer on removing pulldown on 24p footage? at DVinfo.net
Old December 27th, 2008, 02:05 AM   #1
I've Googled this several times, and every person seems to have a different answer. So I thought I'd ask here as a tie breaker.
Both my cameras (HV20, XH-A1) record 24p on tape by pulling down to 29.97, so unless I capture directly to hard disk I end up with a lot of judder.
What is the definitive way to remove pulldown, particularly in Vegas and Premiere Pro? Are there native solutions, or do I have to resort to third-party apps (such as Avisynth)?
J.
Jacques E. Bouchard is offline   Reply With Quote
Old December 27th, 2008, 07:06 AM   #2
Sorry but I use FCP & cinema tools to do any pull down removal if needed depending on the camera used.
By the way, the XH-A1 records true progressive unless you are recording standard Def.
Old December 27th, 2008, 10:23 AM   #3
Use Cineform... works perfect
Old December 27th, 2008, 01:15 PM   #4
I use Cineform NeoHDV. Works with both cameras. I edit mostly Vegas. For Premiere, you get more out of the higher priced packages that would not be usable in Vegas.
Chris J. Barcellos
Old December 27th, 2008, 04:27 PM   #5
David, you are absolutely right. Playback is 60i only when outputting from component. guess I was still scarred from the last time I shot 24p using my HV20. :-)
J.
Old December 27th, 2008, 06:58 PM   #6
The XH-A1 records progressive images, but adds 60i repeat flags. So depending on whether your NLE reports the flags, or ignores them just depends on it, but the pulldown flags are there.
Most mpeg utilities will report the 24f stream from the XH-A1 as 60i. You can remove the flags using the free utility, DGPulldown . You can remove the flags or add them back in.
Old December 28th, 2008, 09:33 AM   #7
I looked at DGPulldown, and it seems to convert from 24p to 29.97. I couldn't find anything about removing pulldown flags.
J.
Old December 28th, 2008, 10:04 AM   #8
J.
There is a readme file that gives a brief explanation.
Basically, you check the radio button for "Custom", then put 23.976 --> 23.976. (Yes, just enter 23.976 into both boxes)
It will remove the flags.
Old December 29th, 2008, 07:53 AM   #9
Thanks Tom.
J.
Old January 5th, 2009, 06:18 PM   #10
Hello,
Not to hijack this thread, but I just shot a project using my XHA1@24p... I normally use FCP, but I am using Premiere Pro for this project.
What does the pull-down affect?
Would you suggest I always remove the pulldown on all of my 24p captured footage?
Micky
Home: See "Work" :)
Work: Canon XH A1, CS3/CS4/CS5/Final Cut Studio/Final Cut Express/Premiere Elements
Micky Hulse is offline   Reply
