add pci-express slots? at DVinfo.net
Old December 1st, 2008, 09:05 AM   #1
I hope this is the correct forum for this.
My workstation has a single PCI-E port.
I'd like to expand that to several PCI-E ports, so I can add an SATA card to connect multiple hard-drives.
Question: Would the expanded ports have the same speed as a single port, or would they divide the total speed?
also, any recommendation on expansion devices??
thanks
Update: Yikes! I just found an "expander" that will turn one PCI-E slot into 7 PCI-E slots...for $4,000!
I guess I need to look in another direction to hook up firewire 800 or expand my sata connections!
update 2:
It seems my computer has only one PCI-E x16, but three PCI-E x 8 (wired as x4)
Will this allow me to hook up a firewire 800 card or SATA expansion???
update 3:
I found a firewire 800 card that only needs an express PCI-E x1 slot!
Robert Bobson is offline   Reply With Quote
Old December 1st, 2008, 10:17 AM   #2
I might be able to help you but I need more info.
What is your actual complete comfiguration?
What is the complete configuration you want achieve?
What is your budget?
Kadafi Marouf is offline   Reply With Quote
Old December 4th, 2008, 07:25 AM   #3
I didn't realize that I had two additional PCIe ports (x8 wired as x4)
so I don't need to add any PCIe ports now.
thanks -
