Raid 0 1 Question - Page 2 at DVinfo.net
Old November 30th, 2008, 08:51 PM   #16
The ICH10R is a decent chip, but still lacks the logic of a dedicated IOP, so for parity calculations it has to revert to the CPU, causing way lesser performance than a dedicated controller. In essence using the on-board chip is about similar to using a low cost Promise card. You get what you pay for. If you use the on-board chip, you will get mediocre performance, without the benefit of dedicated cache memory, dedicated parity calculations and BBM. Expect the sustained transfer rate of a on-board raid versus a raid on a dedicated controller in a raid5 to be around 50% with a much higher CPU load and see the performance loss of on-board to increase with more drives. Any more advanced raid configurations are impossible with on-board chips. You need a dedicated controller for raid 3, 6, 30, 50 or even more esoteric formats. The logic from dedicated controllers for staggered spin-up, spin-down, dynamic expansion, etcetera are major differences, as are setup parameters like stripe size, chunk size, block size and so on.
Not everybody needs a nVidia Quadro 2000 CX card, quite a lot of people are quite happy with on-board video for generic applications. However for HD/HDV editing or other more demanding applications, this may not be enough so they opt for dedicated video cards. The same applies to (SAS) disk controllers.
Harm Millaard is offline   Reply
