QT HD video from After Effects at DVinfo.net
Old May 26th, 2008, 04:27 AM   #1
I am trying to make timelaps videos from pictures in After Effects CS3 on a PC, for export to Vegas on PC and FCP on MAC. And After Effects gives me a lot of export format choises in QTime.
I live in the PAL world, so what HD format (Compression) gives me the best result at a decent filesize?
Arnt
Arnt Mollan
www.mollanmedia.com
Arnt Mollan is offline   Reply With Quote
Old May 26th, 2008, 03:12 PM   #2
if there's no interlacing, my vote would be
PhotoJPEG set to 75% (4:2:2), or
PhotoJPEG set to 100% (4:4:4) if title cards, etc, were added.
caveat
gamma *might* have to be adjusted in FCP using this format; can't remember if FCP handles PhotoJPEG as RGB or YUV. Graeme Nattress (and others) have written about this, but i'm drawing a blank as to where.
-rob
Rob Wood is offline   Reply With Quote
Old May 27th, 2008, 01:15 AM   #3
Thanks Rob, for your reply.
I will have a try at PhotoJPG. I also have a sequence shot in front of a bluescreen, but PhotoJPG do not support alpha channel, as far as I know. What are the alternatives there?
Arnt
Arnt Mollan
www.mollanmedia.com
Old May 28th, 2008, 06:43 AM   #4
uhhh, good question...
i'd probably pick QuickTime-PNG if i needed lossless compression and an alpha.
not speaking from experience on this; just what others have mentioned elsewhere... but yeh, this is the route i'd take the more i think about it.
Old May 28th, 2008, 07:39 AM   #5
PNG and Quicktime (animation) will retain the alpha channel.
Jim Montgomery is offline   Reply With Quote
Old May 30th, 2008, 12:24 PM   #6
Jepp, both are right. It works.
Thank you.
Arnt
Arnt Mollan
www.mollanmedia.com
