Capture Utility For Mac at DVinfo.net
Old May 22nd, 2008, 01:15 AM   #1
I have been searching for a stand alone capture utility for HDV that will split the clips on a new time stamp for recording. Something like scenalyzer for the pc.
Does anyone know of anything for the Mac? I have premiere but it does not work the scene detect right, it crashes when it sees blank time code, and final cut makes one long file. even though it works within fcp to split the clips up, I am using adobe premiere.
Is there a way to bring in the clips or a program to split the clips?
Any help with this HDV work flow would be VERY helpful, I am pulling out my cores!
Thanks a bunch
George Sickler is offline   Reply With Quote
Old May 22nd, 2008, 10:35 AM   #2
I'm suprised PPro crashes on blank timecode. On the PC, it stops capturing, gives you a error message, but the clip IS captured, and then you just start up the capture again when you get to a block of new timecode. I say this only because the error message kinda fooled me the first time I saw it.
Eric Lagerlof is offline   Reply With Quote
Old May 22nd, 2008, 11:17 PM   #3
Nope - it crashes, and trashes what it captured. I have tried for a few days now to get it to work, with scene detect, and it just does not work.
I did get final cut to capture and split clips in apple pro res - 422 but they do not come in as real time in premiere. I really do not want to use final cut, I just want a stable app to capture video footage on a mac, and split according to start stop date stamp. ugh - anyone know of anything?
Old June 23rd, 2008, 06:49 AM   #4
Perhaps a stupid idea, but ever tried iMovie 08 ?
Erwin Vanderhoydonks is offline   Reply With Quote
Old June 28th, 2008, 04:05 PM   #5
George,
If you're using FCP6 then you should be able to import using Log and Capture to ProRes and this will split clips at timecode breaks. (same process as importing HDV, but ProRes codec).
Geoff
Geoff Addis is offline   Reply With Quote
Old June 28th, 2008, 05:41 PM   #6
Capturing with imovie to use in another program is asking for headaches. I did it with 47 hours of feature footage. I eventually burned out and haven't finished editing the monstrosity.
Don't know if it supports HD, but there's a capture utility bundled with the Firewire SDK from Apple (FREE!). It's a sample app to show how to connect to the firewire bus, but it's pretty cool.
it's called...
um...
VHScap or something like that.
Web Youtube Facebook
Cole McDonald is offline   Reply
