Best RAID0 hard drives - Page 3 at DVinfo.net
Old July 27th, 2008, 08:00 PM   #31
Mine's listed as 37MB/s. Is that enough headroom for 20MB/s Cineform?
Old July 28th, 2008, 12:20 AM   #32
For single track yes, but things get dicey if you have multiple tracks that all come from the same disk. Maybe 2 tracks will barely get by, but three or more tracks is not really enough.
Old July 28th, 2008, 07:05 AM   #33
That should work, so long as the drive is defragged.
Robert M Wright is offline   Reply With Quote
Old July 28th, 2008, 11:37 AM   #34
It's a dedicated drive that only is used during capture and editing, it should work then. Once this one's full, I'll get another 32MB cache one with a fast response time (The ST3500320AS) and I'll re-install the current dedicated drive into it's original external casing (yes, I took a Lacie out of it's case, it's basically a ST3500830AS in a case linked through USB 2.0).
Old August 1st, 2008, 11:14 AM   #35
sriped barracude ES series drives.....you pay more for them but they are made to work in an enterprise environment with 24/7 reliability
Tim Harry
Bandwagon Media
Odessa, TX
www.bandwagonhd.com
Timothy Harry is offline   Reply With Quote
Old August 4th, 2008, 08:31 PM   #36
Question about a noise coming from my PC. It is a brand new HP and I installed two new Seagate 500GB drives in RAID0. When the PC starts up and sometimes during usage, there is a high pitch whistle coming from it. I am almost sure it is the drive/s as it started right after I put them in. Is this normal or should I return the drives? Thanks.
www.speedandmotion.com
Duane Steiner is offline   Reply With Quote
Old August 5th, 2008, 12:41 PM   #37
Drives are out and no noise. Question, for just editing HDV is a RAID really needed and would the extra performance even be noticed?
Old August 5th, 2008, 01:08 PM   #38
Definitely, unless your editing is single track only.
Harm Millaard is offline   Reply
