HD Video playback on computer?
I have encoded a 1080x1440i clip with Vegas in Mpg4/H.264. QuickTime, VideoLan, and Windows Media Player all are unable to play it, though I can hear the audio. I have the same problem with Mpeg4 recorded from Dish Satellite. If I encode this same clip at 720x480 (or Mpeg-2), both the VideoLan (ver 8.6d) and Quicktime(ver 7.4) will play it.
Is there a pluggin that I need, and if so where do I get it? In order to make a BluRay compatible high def disc on a regular DVD+R, I believe it has to be in Mpeg 4, not Mpeg-2 . If you have a BluRay burner and are burning to a BluRay disc, then the Mpeg-2 option is also supported. Am I correct on this? Thanks - PK |
#2 | |
You are limited to about 20 minutes of video with .m2t 1080x1440i format, no doubt longer with MPEG-4 but I can't shoot/edit anything worth watching longer than than that (...yet...but I'm working on it!) The .m2t file has to be in a folder called video for the PS3 to be able to view it. I can only view HD video on my PC within Vegas.
Andy K Wilkinson - https://www.shootingimage.co.uk Cambridge (UK) Corporate Video Production |
#3 | |
You mention you are using Vegas 7/DVD Architect 4. Do you use DVD architect, complete with menu's in your HD projects to Blu Ray? What encoding/bit rate do you use in V7, and how do you set DVD Architect to work with an HD file? You put the m2t file in a folder labeled Video. Is the audio in a seperate file/folder? Thanks - PK |
m2t playback on DVD+R's
Opps! Sorry, I made a mistake (one too many beers with friends in the pub tonight I think). I DO NOT use Sony DVD Architect to burn these .m2t files once I've finished editing in Vegas 7, I simply render them out as a .m2t for burning in HD and render another version out to Std Def MPEG-2 Main Concept for normal DVD production in DVDA. Sorry for the confusion!
With the HD .m2t, that file is simply put in a folder called video and that folder is burnt onto a normal DVD+R "data" disc with standard (in my case Sonic Record Now) DVD burning software, not as a DVD-Video with Sony's DVDA. On the PS3 it will just play the file all the way through, you don't get fancy options like A to B repeats, I think, certainly not any menu options etc....at least not with a PS3. You can pause it or fast FWD/REW at various speeds but that is about it. Still blumming good tho!!!! So a question, will these DVD+R discs I'm making with .m2t HD files ALSO play OK on a HD-DVD player?..it sounds like they will if I've read you post correctly Paul. Good news if true....Just looking for maximum versatility while they are still around.
Andy K Wilkinson - https://www.shootingimage.co.uk Cambridge (UK) Corporate Video Production Last edited by Andy Wilkinson; February 20th, 2008 at 05:08 PM. |
