DIVX, MP4 and AVIX at DVinfo.net
Old January 18th, 2008, 09:43 PM   #1
DIVX, MP4 and AVIX
I am wondering if Sorenson Squeeze 4.5 MP4 option is the same file as produced for DivX? And what is AVIX then?
Namely, if I want to produce a AVIX (or DIVX) playable file, must I get the DIVX encoder then? Any other software available to do that?
My source will be 720p HD coming from Panasonic HVX202 (DVCPRO HD) -> Canopus EDIUS -> Canopus HQ codec.
TingSern Wong is offline   Reply With Quote
Old January 22nd, 2008, 07:27 PM   #2
Not sure what AVIX is, but I can tell you about DIVX. You either need the DIVX encoder (I think they call it Doctor DIVX), or the codec at the minimum. Some compression software will do the actual compression as long as the codec is installed. No other software will do it unless specifically designed to do that or having the codec installed. In other words, no codec = no encoding.
Ervin Farkas
www.AtlantaLegalVideo.com
Old January 22nd, 2008, 08:10 PM   #3
Okay - thanks. Will get Doctor DIVX then. It is cheap software anyway.
