Another laptop for HDV thread
Ok, before you guys start throwing rocks I have used the search engine and I have found several threads about different laptops for editing HD/HDV, but I'm still cannot make up my mind. Some people say you can only do decent work if you spend a fortune...others say you can get something good to work with for like 700$.
Right now I have a desktop that has been able to do the job, but since I might be moving I may just buy a laptop (which can also help me on the field, since I travel a lot). My current desktop setting is an AMD DUAL 64 3800+ with 4 GB ram and 2 350HD at 7200rpm. I capture via firewire and I do my video work with premiere pro 2 (will move to CS3) and after fx. I have cineform's aspect hd installed. If possible I would like to stay under 1000 euros. Is there such a solution? What should I be looking for? Oh, yes, I forgot a small detail. I would like the laptop to have a 17 inch monitor (preferably with a 1920 x 1200 resolution...or at least 1680 x 1050). Last edited by Rafael Lopes; November 18th, 2007 at 08:20 AM. |
I went to Dell's website where you can build your own laptop and I managed to come up with this:
Processor: Intel® Core™ 2 Duo T7700 (2,4 GHz, 800 MHz, caché nivel 2 of 4 MB) Monitor: UltraSharp™ WUXGA de 17" (1920 x 1200) with TrueLife Memory: SDRAM DDR2 4096 MB 667 MHz dual layer [2x2048 HD: 2 500 GB SATA (2 X 250 GB at 5.400 rpm)...I really want 7200 instead Batery: 85 WHr Firewire: it doesn't say anything about it. Cost: 1900 euros This is WAY more than I'd like to pay. I'm sure I'm paying A LOT for the brand name here. There's got to be other options. |
I use a very nice XPS Dell 2GB RAM, Centrino Duo, 7200 hard drive. Cost me US$1100 but I'm afraid that model is discontinued. One thing about Dell, if you call them, the operators have full access to all the accessories, so you can customize the different laptop models to your specifications. For some reason, they limit certain choices online, probably to speed up their build time, but calling directly has given me more options to choose from.
"Ultimately, the most extraordinary thing, in a frame, is a human being." - Martin Scorsese |
#4 | |
#5 |
bump.................
#6 |
I'm running an HP at 1.8 ghz dual with 2 gigs of ram, as long as you've got Cineform, and you do :) You're golden, once I get into AE and 3Dsmax to create complex VFX it becomes an issue but for editing and simple AE work it works perfectly, on the go it's indespensable. Try getting the new Asus it has HD monitoring possibilites and it's fairly affordable I think u can get one for about 2000$ on amazon.com and Cinevate is using it for monitoring HD and focus assist, so it must be good. but for 1000 euros you shouldn't have a problem finidng a more than decent machine. Good luck.
G2S-Extreme Laptop with a 17" 1920x1200 screen is probably the top dog, but that thins is 3900$ sorry for the mistake http://www.amazon.com/ASUS-F3Sv-B2-B...497337&sr=1-23 is a possibilty for you as well. I guess it's just a matter of you chosing what's best for you, as far as power and aesthetics. Good luck man, can't wait to see what you produce :) Or try configuring a model with HP seems to be affordable, just configured an AMD 2.3 dual core with 4 gigs of ram an Nvidia VC 128mb and 1 year accidental damage for less than 1000 euros. |
#7 |
Thanks. Next weekend I'll probably visit a couple of stores to get a better look of what is what.
#8 |
Any more suggestions/alternatives?
#9 |
One last bump....
#10 |
Check out this laptop:
http://www.bhphotovideo.com/c/produc..._Notebook.html It has a 21 inch screen! |
#11 |
I would love to get some info on this as well, I have a sony Vaio vgn-A190
http://reviews.cnet.com/laptops/sony...-30898700.html I went to the Sony store at my nearby mall. There newer version is $3000 and change the only real difference is the 2.4 GHz mine is 1.7 GHz. Same screen same everything, So I started to upgrade it I put in 2 gig of ram I'm upgrading the HD from 60 to 100 that's the only size the had for 7200rpm. I figured I would need at least 60 for my C drive and use exclusively external drives to save data. I'm hoping I can edit HD on this laptop if not it will used as a Internet take every where job and I will have to build a desktop. any thoughts please feel free to give them thanks C |
