New project settings for Canon XH-A1 footage
What settings to use in Edius 4.0 when capturing HDV footage from a new Canon XH-A1 camera? I have a dual woodcrest processor/dual core setup with several G-raid drives for storage...
The camera seems to record at 1920 x 1080 and feed it out via the firewire port to Edius at 1440x1080... not sure what the proper project settings would be in edius 4.0... Several options in the dialog box: OHCI Full HD 1080/59.94 I (1920 x1080) 29.97 top field first 48/16 bit HDCAM/HDV 1080/59.94i (1440x1080) 29.97 top field first, 48/16 HDV 1080/29.97p (1440x1080) 29.97 progressive 48/16bit I believe I should use the third setting?? Last edited by Rob Epple; April 27th, 2007 at 07:15 AM. Reason: corrections |
#2 | |
If you're recording in 60i mode, then the second option (59.94i) is appropriate. Your camera has "30F" mode. Are you using that? If so, then I believe 29.97p would be appropriate. Last edited by Roy Colquitt; May 1st, 2007 at 10:54 AM. Reason: to make sense |
Were are you located, I'm In AZ using two A-1's and Edius, been so for a little over a month. I'll check my setting and get back with you, ps, I'm currently using Roxio Creator 9 for my DVD's burned about 30 costers. still trying to get the best output from Edius to Roxio, what DVD app are you using, I plan on upgrading to HD software and burner in the near future..Gary
I export out of Edius to procoder express to MPEG-2 program stream (.m2p) using 2 pass VBR. I then use Adobe Encore 2 to create the DVD. The quality is awesome. I also have (2) A1's and a HV20. I shoot and edit all my video in HDV using HDCAM/HDV 1080/59.94i ((1440x1080) 29.97 top field first, 48/16).
I have not shot in 24F mode yet but I do not believe edius supports that yet - maybe 4.5 will. Maybe someone has a solution? |
#5 |
Hi Tom, I just read your post, I'm also shooting A-1's, editing in edius, I've burned a lot of poor quality DVD's, I'm using Roxio Creator 9 to author and burn, (using various bit rates 6-8) I'm wonering if the "weak link" is roxio, your apparently happy with encore, will their latest release do HD etc. Gary
#6 | |
#7 |
I haven't worked with the 24F yet. Encoder times vary according to processor speed. I have a Quad core 2.66 and it takes about 50min.
