Ripple audio tracks? at DVinfo.net
Go Back   DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
All flavors of Edius; other Grass Valley / Canopus software & hardware.
Old April 23rd, 2007, 12:51 PM   #1
Is there a way of having an added audio piece, on an "audio Track" ripple down the track with the other VA tracks, tried everthing that I could think of, this is necessary when adding a clip on a VA track preceeding the added audio piece, Gary
Gary J. Walker is offline   Reply With Quote
Old April 23rd, 2007, 04:29 PM   #2
Jolly Mon
Do you have ripple mode on? ;)
TSS / Grass Valley
Mike Downey is offline   Reply With Quote
Old April 23rd, 2007, 06:08 PM   #3
Mike, wouldn't that be Sync Mode?
Roy Colquitt is offline   Reply With Quote
Old April 23rd, 2007, 07:55 PM   #4
Jolly Mon
nope... in 4.o and higher there is a button next to the mode button that is called ripple. :)
Now if you are not on 4.0 or higher please make sure that under the mode button that sync is selected.
Mike
TSS / Grass Valley
Old April 23rd, 2007, 07:56 PM   #5
Jolly Mon
Hi Roy... Great to see ya! :)
Mike
TSS / Grass Valley
Old April 23rd, 2007, 08:25 PM   #6
You are correct sir,, I always have ripple on but accidentally switched it off, thats another pizza for you, but their's a catch...one more question, I'm able to make a SD DVD in roxio, BUT I must have some setting wrong in Edius, Problem is the image scene on the DVD (Played on a 42" 1080P Samsung LCD) is like a 16x9 pic in pic taking up about 80% of the screen, black sides and top and bottom, proper size but not full screen...? I'm using speed encoder, the clip properties is 1440 x1080. 1,3333 (16x9) aspect ratio, under speed encoder I don't think their is a size option..PS output device settings NHX-E160Hz, output format, HDV 1080/29.97p over 59.94i....(this is my last stumbling block hope you can help. Gary..Thanks for everything Mike.
Old April 23rd, 2007, 09:12 PM   #7
Jolly Mon
Check the Aspect ratio settings on the set. Try different settings and see if that fixes it.
Mike
TSS / Grass Valley
  You are here: DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
