What DVD app....
Shooting with two Canon A-1's in HDV, and editing in Edius...has anyone used rixio creator 9 to make SD DVD's I've used every format output setting edius has to offer with only garbage jagged DVD's and garbled audio....if anyone is using roxio please pass on the proper output settings from Edius and in roxio...(I've burned thousands of SD DVD from rex-edit to a DVD studio pro,no problem, but trying to fade out the Mac.
OR just let me know what DVD app works well with Edius....Help Please...Gary |
adobe encore
Thanks Ted, what Edius format do you output for best results in SD and HDV footage. etc. Thanks again. Gary
Gary,
for outputing to Dvd via edius. My workflow is as follows; For SD Edit in a SD preset,-> export print to file, select, procoder express, select dvd preset(I use m2p file for authoring), ->use the m2p in adobe encore. For my HD work for digital cinema Edit in an HD preset,-> export print to file, select, WMV. I archive in canopus HQ. |
#5 |
Thanks very very much lifeline, I'll give it a go later today, looking at Edius, export, Procoder express for edius Wizard-I then went to "Select a generic target"?---6th choice down is WindowsMedia, - next-next "Job Summary states that the output format is only320x240 15fps...I don't thing I have the right setting do I????.Gary
#6 |
Ted, I found the export file your speaking about and will give it a go. Gary, Thanks..
