Edius 4.24 is now available - Page 2 at DVinfo.net
Go Back   DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
All flavors of Edius; other Grass Valley / Canopus software & hardware.
Old April 15th, 2007, 08:34 AM   #16
Ruler of the DownUnder UnderWorld
Got it.
I must off deleted some files in the windows directory somewhere when I did the last mirror image backup of my complete C: drive to get the mirror image file as small as possible. Windows dumps files all over the place when you install software etc.
I reinstalled Edius from the disk over the top and the new update installed no problems.
I remember I had the same problem with Dreamweaver once thinking about it now.
OKAY lets see how it goes consolidating.
Paul Wags is offline   Reply With Quote
Old April 15th, 2007, 09:55 AM   #17
Jolly Mon
Thank you for the specs... I will send them on :)
TSS / Grass Valley
Mike Downey is offline   Reply With Quote
Old April 16th, 2007, 02:03 PM   #18
BTW, I am also using a DVStorm2
Old April 18th, 2007, 01:24 PM   #19
Another thing on 4.24 :
to Put a marker : V - it's OK
But to delete the marker : V again is not possible.
I do delete by right-clic menu (too long)
Besides, the option "delete all markers" don't works.
Marc
Marc Barillere is offline   Reply With Quote
Old April 18th, 2007, 06:49 PM   #20
Jolly Mon
Also sent along! :)
Thank you for letting me know!
Mike
TSS / Grass Valley
Old April 19th, 2007, 12:51 AM   #21
During the correction of this point ... the arrival of the awaited clip marker will be appreciate.
For the 4.5 version ?
Marc
Old April 19th, 2007, 03:35 AM   #22
Jolly Mon
It has been asked for but no word whether it is going to be in 4.5.
Mike
TSS / Grass Valley
Old April 19th, 2007, 06:32 AM   #23
We hope for an happy surprise ...
Marc
Old April 19th, 2007, 07:39 AM   #24
Indeed. I have been asking for clip markers since version 1. So invaluable for Multicam work. I'll believe it when I see it.
Mark Morreau is offline   Reply With Quote
Old April 19th, 2007, 01:42 PM   #25
And if is not too much to require : TL numbered markers :)
Marc
Old April 19th, 2007, 05:08 PM   #26
You'll be wanting keyframes for all the effects next.
And full Alpha channel support too, I suppose? ;)
Old April 19th, 2007, 06:11 PM   #27
Another thing, since the Canous forums are down, this is the only game in town.
When I add a quick title, the title is made to the length of the in and out, not to the 5 seconds that is listed in the settings menu.
Old April 19th, 2007, 10:01 PM   #28
Jolly Mon
This is a feature that I use all of the time. The ability to designate where the title is going to go and how long it is going to be is not a bug.
Mike
TSS / Grass Valley
Old April 20th, 2007, 08:18 AM   #29
Is there a way, Mike. to have the choice of inserting a title with the default duration (Tim's preference) rather than between the in and out points (your preference?).
If you're laying down lots of titles - like, for example, a simple credit sequence - then Tim's default duration method is going to be a lot quicker and easier than having to set in and out points for each one.
Old April 20th, 2007, 08:33 AM   #30
Jolly Mon
Select the X Key and the in and outs disappear
Mike
TSS / Grass Valley
  You are here: DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
