EDIUS Has Done It at DVinfo.net
Go Back   DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
All flavors of Edius; other Grass Valley / Canopus software & hardware.
Old February 5th, 2007, 08:57 AM   #1
Ruler of the DownUnder UnderWorld
EDIUS Has Done It
Well we started with Premiere Pro/Aspect HD but ended up re doing it all with EDIUS using the Canopus HQ codec.
Here is a sneak peek at out new underwater DVD coming out soon shot with HDV cameras.
http://www.hdvunderwater.com/ningaloo/ningaloodvd.htm
Paul Wags is offline   Reply With Quote
Old February 5th, 2007, 09:13 AM   #2
As an edius user from the start, well done should be a winner for you
Regards
Mick
Mick Jenner is offline   Reply With Quote
Old February 5th, 2007, 08:13 PM   #3
Looks Great! What camera/cameras did you use?
Old February 6th, 2007, 01:26 AM   #4
Is there a reason why you switched from an editing program/codec to another ?
Old February 6th, 2007, 03:15 AM   #5
Cheers
Used a FX1 and A1 in Amphibico Phenom & EVO housings.
We changed codecs from Prem Pro & Aspect HD because.....
Could convert to the Canopus HQ in realtime on our 3 GIG PC.
Better realtime, vary Colour Correction.
Better realtime, vary slow mo.
Less banding in openwater shots with CC added.
Better m2t out encodes with Procoder Express.
Progressive DVD MPEG2 spec files straight out from the timeline.
We did lots of side by side tests on the same footage to compare. Even my non editing partner could see the difference.
I found these two m2t clips to compare... 21 megs each, have a look.
http://www.hdvunderwater.com/videoclips/aspect.m2t
http://www.hdvunderwater.com/videoclips/edius.m2t
  You are here: DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
