Video bits left on timeline at DVinfo.net
Go Back   DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
All flavors of Edius; other Grass Valley / Canopus software & hardware.
Old December 26th, 2014, 11:36 PM   #1
Problem, I have Edius 7 plus. Sometimes when I move clips around, shorten, or even cut I notice that I am left with video bits that I have to find and cut from the time line. Is this solved with a software update or is this a set up problem? I usually turn off Rippple Mode, Snap to event, and Insert. These are VA tracks where the problem occurs. Thanks for advice.
Ralph Bowman is offline   Reply With Quote
Old December 29th, 2014, 11:20 AM   #2
Re: Video bits left on timeline
What are the video bits? Do the include audio?
Are they a continuation of another clip on the time line that you moved?
dpalomaki@dspalomaki.com
Old December 29th, 2014, 02:32 PM   #3
The bits are so small I cannot see or hear audio at this time. I will check out more carefully so can answer your question. Yes, they are bits of clips that I have moved.
Thanks for responding.
Old January 5th, 2015, 12:43 PM   #4
Sounds like a frame or two from the end of a cut that resulted from inserting a clip to the timeline not at a clip boundary. Zoom way in, perhaps to 1 frame resolution, to see it,
Don Palomaki is offline   Reply
  You are here: DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
