Edius 6.5 and Canon Vixia HG20 no audio at DVinfo.net
Go Back   DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
All flavors of Edius; other Grass Valley / Canopus software & hardware.
Old April 28th, 2014, 10:42 AM   #1
Has anyone been able to get audio on the timeline when using a Canon HG20 /
The video shows up but can't hear any audio?
When I put the same clip in Premiere I get audio.
AL
Al Gardner is offline   Reply With Quote
Old May 3rd, 2014, 01:54 PM   #2
Re: Edius 6.5 and Canon Vixia HG20 no audio
Analyze the clip with something like MediaInfo and post the findings here.
I have never ever found any video or audio format not to play in Edius - there is a reason their motto is "edit anything"...
Ervin Farkas
www.AtlantaLegalVideo.com
Old May 3rd, 2014, 08:25 PM   #3
Is it showing no waveform at all? It's just AVCHD with 2 channel dolby, should show up fine.
Woody Sanford is offline   Reply With Quote
Old May 4th, 2014, 04:53 AM   #4
> but can't hear any audio ??
only on the timeline ??
or timeline (= recorder-windows) AND the player-windows ??
what tells "MediaInfo" ... 2 channel or 5.1 channel ??
Hans Stephan is offline   Reply With Quote
Old May 27th, 2014, 02:19 PM   #5
Don't have a G20, but I work in Edius with a bunch of Canon camcorders. I don't use their software, but take the raw MPEG Transport Stream files from the SD cards. Have you tried that? They are in Private/AVCHD/BDMV/Stream with an MTS suffix.
Chris DeVoe is offline   Reply With Quote
Old May 29th, 2014, 07:14 AM   #6
Did the issue get resolved?
No problems her with AVCHD from XA10 or XA20.
Are you putting the clip on a VA track or A V track
And check your audio mapping.
dpalomaki@dspalomaki.com
Don Palomaki is offline   Reply
  You are here: DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
