Most export settings greyed out at DVinfo.net
Go Back   DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
All flavors of Edius; other Grass Valley / Canopus software & hardware.
Old February 12th, 2013, 08:39 PM   #1
My Edius 6.0.6 export settings (with the exception of batch export) are greyed out. I have toggled the PLR/REC switch to REC but the problem persists.
What else can I try?
Old February 13th, 2013, 06:07 PM   #2
Re: Most export settings greyed out
Project settings not compatible with your desired output settings will prevent Edius from exporting. For example you can't export from a 24P project to DVD - your project settings need to be either 50i PAL or 60i NTSC for you to be able to author a DVD directly from the timeline. In other words, you will have to start with a PAL or NTSC project in order to export directly to DVD.
Last resort... give your compatriot Anton over in Sydney a call, he's the Edius authority in Australia.
Ervin Farkas
www.AtlantaLegalVideo.com
Old February 14th, 2013, 01:12 AM   #3
Thanks Ervin,
Since posting I have made some progress. The greying out problem disappeared when I opened a new project. I am working with 1080p50 clips in MTS. I have some very long takes that I want to trim and/or take sub-clips from and then store them in a library. At the moment things seem to be working so thanks for the interest.
Old February 14th, 2013, 05:12 PM   #4
this simply means that you have an in and out with 0 duration marked on the timeline, meaning the outpoint is in the same spot as the in point
press X on keyboard to clear in and out
Anton Strauss
www.videoproductions.com.au
Anton Strauss is offline   Reply With Quote
Old February 16th, 2013, 01:49 AM   #5
Thanks Anton,
As I mentioned above the “greying out” problem disappeared when I opened a new project.
Old February 19th, 2013, 01:30 PM   #6
This tip will surely come in handy in the future. Thank you sir.
Luis Valenzuela is offline   Reply
  You are here: DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
