Help with Edius and TitleMotionPro at DVinfo.net
Go Back   DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
All flavors of Edius; other Grass Valley / Canopus software & hardware.
Old May 10th, 2012, 04:16 AM   #1
I have a little issue with Edius and Title Motion and I thought maybe there is someone here who can help me.
Where I work, I use Premiere 3 and Edius 5. I want to optimize a little bit the editing process and it has went well with Premiere, but I'm pretty new to Edius, so that is why I need your help.
This image should help:
http://i49.tinypic.com/1zcn8uw.jpg
So my problem is:
The green clip is a lower-third graphic.
In the adjacent title, I created a Title Motion Pro clip.
The picture was taken the second I saved the title.
As you can see the title is smaller than the green clip.
I know it can be set to be longer, because it does so on one computer, but on these other two behaves as in the picture.
So this is my question: where do I set the predefined length of a new title either in Edius 5 or Premiere Pro?
Marius Tatarasanu is offline   Reply With Quote
Old May 10th, 2012, 10:39 PM   #2
Re: Help with Edius and TitleMotionPro
you can just grab the right edge of the title in timeline and stretch it to match the duration of the graphic
or go to application settings and change the default duration, be sure you untick add between in and out
http://www.videoproductions.com.au/a...settings03.gif
Anton Strauss
Anton Strauss is offline   Reply With Quote
Old May 11th, 2012, 05:10 AM   #3
Thank you so much! That did the trick, altough my menus are a little bit different and I had to search a little until I found it.
Altough it's little, now I can save seconds!
Old May 13th, 2012, 09:51 PM   #4
I suggest you update your EDIUS5 to 5.51 (free)
Anton Strauss
  You are here: DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
