asus motherboards at DVinfo.net
Go Back   DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
All flavors of Edius; other Grass Valley / Canopus software & hardware.
Old April 15th, 2011, 05:30 PM   #1
asus motherboards
read about these boards being very similar.
anyone have pro/con on these and which to go with for editing HD, AVCHD
asus px58 D-E
asus sabertooth x58
thanks
Jim Stamos is offline   Reply With Quote
Old April 16th, 2011, 07:44 AM   #2
Re: asus motherboards
Hi
If the motherboards are based on the same chipset there is no difference to speak off between them, certainly performance wise. The differences really come down to additional peripherals or interfaces added to the board.
Regards
Phil
Phil Lee is offline   Reply With Quote
Old June 14th, 2011, 07:39 PM   #3
I will also state the same... the same chip X58 will be the same across different models of the mainboard but the chipset and tools are the same... extra add ins such as more usb ports, or serial controllers or External SATA Ports. Other wise the mainboards are all the same and work all the same way, as long as its the same chipset. (CPU, Video Card, RAM will make the difference).
Dipesh Parmar is offline   Reply
  You are here: DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
