neo to 5.0 ? at DVinfo.net
Go Back   DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
All flavors of Edius; other Grass Valley / Canopus software & hardware.
Old May 28th, 2010, 09:39 PM   #1
neo to 5.0 ?
Good evening,
Was wondering if projects and files can be transferred back and forth between neo and 5.0.
dale
thanks
DATS ALL FOLKS
Dale W. Guthormsen
Old May 29th, 2010, 07:27 PM   #2
Originally Posted by Dale Guthormsen View Post
Good evening,
dale
thanks
Dale - I had the same question and sent off to Edius Tech support: The response was as long as you DON'T apply any features from Edius 5 that aren't available in Neo 2/2.5 booster, you can interchange back and forth. Neo 2/2.5 Booster would be a good for the basic cutting, then bring into Edius 5.1x-5.5 for grading/finishing.
The only sure way to verify is to have two computers with one of each NLE and test for yourself with an external hard drive with a test project.
Cliff Etzel - Photographer
Website | Blog
Cliff Etzel is offline   Reply With Quote
Old July 15th, 2010, 09:52 PM   #3
Cliff is correct...you can switch them.
Pat Sipes is offline   Reply
  You are here: DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
