Help - can't export VO at DVinfo.net
Go Back   DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
All flavors of Edius; other Grass Valley / Canopus software & hardware.
Old May 26th, 2010, 08:25 AM   #1
Hi guys and ladies... :-)
I am doing voiceovers for the first time ever in my life.
While it works OK in Edius, creates the VO file and inserts it on th 1A line, I can't find a way to export the video AND the VO as one .MOV file.
I select "Print to file" and then select 4 channel audio ('cause I already have 2 audio channels in the video), but when I play the reaulting MOV, the voiceover is not there.
Any clue what I do wrong?
Any help much appreciated!
Peter in Denmark
Peter Erfurt is offline   Reply With Quote
Old May 26th, 2010, 10:21 AM   #2
Do you hear the VO when you play the video on your PC? Try exporting to another format... does MOV support four individual audio tracks?
Ervin Farkas
www.AtlantaLegalVideo.com
Old May 26th, 2010, 12:45 PM   #3
Hi Ervin,
Yes, I hear the VO fine when I listen to the timeline. But you may have a point with the MOV format. I will try to export with the Canopus codec and let you know what happens.
Thanks in advance :-)
Peter
Old May 26th, 2010, 06:56 PM   #4
why would you select 4 channel audio export
you can have 100's channels in edius and export as standard 2 channel mov
Anton Strauss
www.videoproductions.com.au
Anton Strauss is offline   Reply
  You are here: DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
