feel like a moron.....help! at DVinfo.net
Go Back   DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
All flavors of Edius; other Grass Valley / Canopus software & hardware.
Old January 18th, 2010, 11:30 PM   #1
Edius users, I am trying out the edius software, and I feel like an idoit, but how do i do a simple dissolve? I see all other transitions, but where is the simple dissolve? Help a stooge, please.
www.gregoryfilms.com
(keep the faith....better yet, pass it on!)
Thomas Gregory is offline   Reply With Quote
Old January 19th, 2010, 12:19 AM   #2
Straight forward Thomas - make sure you are in the Transitions folder, open the 2D folder, grab the dissolve icon and drag it onto the clip - it will insert first at the beginning, grab it again, it will insert one at the end. Default is 4 seconds and can be adjusted.
HTH
Cliff Etzel - Photographer
Website | Blog
Cliff Etzel is offline   Reply With Quote
Old January 19th, 2010, 11:00 PM   #3
well, now that i'm a bit less stupid, I've got it figured out. I'm using the edius Neo on a laptop, and it seems to be perfect for my same-day-edits at wedding productions.
Old January 20th, 2010, 08:14 PM   #4
If you set Dissolve as the default transition, you can apply it with one click, using the icon above the timeline.
Richard
Richard Hunter is offline   Reply With Quote
Old January 20th, 2010, 08:28 PM   #5
also, place cursor in between 2 clips and press Alt+1 or Alt+2 or Alt+3
Alt+1 = 1 second
Alt+2 = 2 seconds
Alt+3 = 3 seconds
Anton Strauss
www.videoproductions.com.au
Anton Strauss is offline   Reply With Quote
Old January 20th, 2010, 11:20 PM   #6
Thanks Anton. I'd forgotten about that shortcut, it's actually very useful.
Richard
  You are here: DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
