SD to HD DivX in Canopus Procoder 2 at DVinfo.net
Go Back   DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
All flavors of Edius; other Grass Valley / Canopus software & hardware.
Old May 9th, 2005, 11:20 AM   #1
Hi,
Greetings from Serbia !
I want to compress SD video (captured from miniDV) to HD DivX format (1280x720 @ 3000kbs) in Procoder 2. Would I be able to play it on stand-alone DVD-DivX players, and watch it on SD or HD TV ?
Should I deinterlace it or not. Will I see interlacing on 100Hz Tv, like I can see it on my computer monitor ?
Thanks !
Marko.
Marko Xorg is offline   Reply With Quote
Old May 9th, 2005, 09:13 PM   #2
Marko: there's little point in upsampling SD material to HD resolution for display purposes, since you can't create detail which isn't present in the source material. De-interlacing is potentially more useful, but that depends on whether you're going to play the video on a progressive-scan display or a standard interlaced TV.
Kevin Shaw is offline   Reply
  You are here: DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
