Canopus HQ Codec - Page 2 at DVinfo.net
Go Back   DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
All flavors of Edius; other Grass Valley / Canopus software & hardware.
Old February 26th, 2005, 09:35 AM   #16
Final Update
After visiting the Canopus HDV Education site I have a better understanding of how the codec works.
The issues I was experiencing above arise because once the HQ Codec has determined the complexity of the scene, it will NOT allocate any more bits to the encode regardless of the higher file size setting, so for my test above 80 mbps is all the scene needed and it refused to allocate more.
To confirm this I added a shed load of grain to the clip and recompressed it with
Q = 4, Size = 100%
Sure enough the HQ Codec obliged by returning a compressed data rate of a whopping 340mbps
In conclusion the file size parameter is not a demand but a limiter parameter.
I am far happier now and my strategy will be to encode
Q = 4, Size = 60%,
(NB this is 10% better than superfine and I am calling it Atomic)
safe in the knowledge that low complexity scenes will never be this high because of the HQ internal quality algorithm.
John Jay
Beware ***PLUGGER-BYTES***
John Jay is offline   Reply With Quote
Old February 26th, 2005, 12:17 PM   #17
CTO, CineForm Inc.
This reflects the nature of a constant quality codec. Same design philosophy went in CFHD, although I've never seen bit-rates that high, probably due to base transform efficiency. I would still like to try it out myself. Anyone at Canopus willing to send an evalualion verison of the software?
Old February 26th, 2005, 10:34 PM   #18
"although I've never seen bit-rates that high, probably due to base transform efficiency" Why does that surprise you David? The goal of the codec is different than yours. It was designed first and foremost to do full frame full resolution out to monitor so it makes a super DV with 4-6x the bitrate encoding.....Your codec is a wavelet that is partially decoded at least using accelerated preview. It is indeed a very efficient way to go and you can argue the pictures values are all there at lower resolution till the cows come in...I know they are with HQ. To quote a friend of yours and mine( I will try and get him to intro us at NAB) in a debate over the same subject we have discussed here and elsewhere
"Canopus' HQ codec IS beautiful stuff. I think to a point the hangup on codecs is splitting hairs. " He is a great supporter of your codec and I think he is right....so lets not split hairs.
Randy Donato is offline   Reply With Quote
Old February 26th, 2005, 11:22 PM   #19
Hmmm...interesting discussion. For me, output quality on playback is usually going to be a secondary consideration to the codec being as transparent as possible through several generations.
David, I'll look forward to your planned comparison, sometime.
Old February 27th, 2005, 08:37 AM   #20
"the codec being as transparent as possible through several generations."
Don't get me wrong that is very important and Hq is bettter than most if not all DCT based codecs. What you look for in a high quality DCT is how the filtering takes care of high contrast lines within about about 30 degress of horizontal or vertical....they tend to show aliasing(stair stepping) with lesser DCT based codecs. The bitrate is also important to whether this appears as a problem or not and as David admits Canopus uses "Constant Quality" aka variable bitrate structure just like Cineform. Hq does a great job. Mosquito noise around titles in low resolution DCT based codecs is also inherent in the compression scheme depending on the specified data size...again handled differently by different DCT codecs and not nearly a real problem (visually detectable) in high resolution with a decent data size.
  You are here: DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
