New VTS audio plug in issue at DVinfo.net
Go Back   DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
All flavors of Edius; other Grass Valley / Canopus software & hardware.
Old January 28th, 2009, 10:50 PM   #1
Hi all
I am using the new limiter that comes with the audio VTS plug in with Edius 5 and it works really well BUT it keeps on returning back to the default setting.
Its really annoying because I am doing a massive audio tweak of a dance concert and allowing for the “easy limiting” setting that I am using.
I have saved the the Easy Limiting set up as a new filter and called it “Limiter – Easy limiting” but when I drop it into the time line it goes back to the default setting.
Wondering if these two problems are a bug?
Any clues on this one welcome.
Tar
Martin
Martin Duffy is offline   Reply With Quote
Old January 31st, 2009, 04:52 AM   #2
Are you using Edius 5.01 and the Izotope 5.01 update?
Paul
Another Sunny Day in Ibiza
Paul Newman is offline   Reply With Quote
Old February 1st, 2009, 05:29 PM   #3
5.01
I will try the update. Thanks.
  You are here: DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
