change capture location in edius?
Hello, how do I change folder for storing captured files in Edius 4.5? I cannot find this option anywhere, even in Help. Thanks!
Look under SETTINGS/PROJECT SETTINGS. There you can change the destination.
Thanks Ivan, that was the first dialogue I checked, but it's not there, even under submenus. All i can change is output device/format, codec and track settings. Weird...
IN the absense of any other change, the captured files will store on the same drive as the project setting. But if you use the Capture in Edius, you can go to Settings>Application Settings and check the Confirm location of Captured files and then the confirm before capture and it will allow you to choose any drive as your destination.
#5 |
That did the trick. Thanks Pat!
