Thread Tools
Search this Thread
Help me set up a green screen!
I bought a cloth green screen- supposedly a "professional" one, however it seems a bit thin to me. But anyways, it's fairly large- not sure of the dimensions, maybe 10 feet by 8 feet. It's hanging from stands - and pinned so that it's tight. There arent many wrinkles. I'm lighting it using very cheap methods I'm aware of that. I bought a few of those floursecent work lamps-- three that are on stands , and two that sit on the floor. Of course I removed the steel cages from them to keep them from creating shadows. My first attempt at light positioning had two stand lights lighting the green screen, then a two floor lights near the green screen but facing the subject to create backlight- or so i though, but im not sure if it really did much. and then one stand in from of the camera aiming at the subject - which created a slight shadow on the green screen. My biggest problem was that I got a lot of green spill on my subject, but im not really sure why. My second problem is that I'm really not sure on where I should place the lights for best positioning. and I dont know how to help the green spill problem. Thanks for any suggestions. I can always take pics of my setup if it helps, or post some clips of my captured footage.
I've found this helpful, enjoy!
http://www.film-and-video.com/broadc...eenscreen.html |
Sponsor: VASST
If you’re getting a lot of spill then your subject is too close the green screen. They should be at least 5 feet away at a minimum. Also make sure you light the subject separate from the screen. Check out these two tutorials by Keith Kolbo:
Chromakey Techniques for Budget Productions Gain a better understanding of Chromakey / Greenscreen / Bluescreen These should help you get good results. ~jr
Developer: VASST Ultimate S, Scattershot 3D, Mayhem, FASST Apps, and other VASST Software plug-ins Web Site: www.johnrofrano.com |
Hey
i havent looked at the tuturials in the earlier posts, ive done about 40 days of greenscreen photography so here's my ultra simple set up: 4-6 red heads (for the screen only) Full "effect" green Gel's the one's Dj's use, which are extremely dense Studios Space of about 6*6 meters u start off by making sure the fabric is well fastened and streched. if u need to see the performer's legs than u need a green floor. I hope the material u are using is matte and not reflective , glossy or plastic coverd(iv'e seen horrible "pro" screens in my day) Place the reds on the sides of the screen about 2 meters from it, so they get a good spread on the screen (make sure they are on Flood and not Spot setting) so what u need to do is basically get an even spread with the red heads on the screen , covering them with the green Gels. if u can also light from abouve the screen its great but using them on tripods on the sides of the screen works great also. once u get a even spread and no visible "hot spots" from the lights' youre good to go. a good idea would be to use a polariser also, to get rid of highlights from the key lights u will use to light people on the screen. just make sure they dont step into the green light, and when u dont need to see the floor, throw some black fabric on it to reduce spill on the actors. Good Luck Lior. |
#5 |
use kickers to burn the edges
hi
get 2or 3 kickers with magenta gel to make a high light on left right and top tomake edges with highlights i personally don;t like but this is easiet way to kill the spill if u can't go distance from the green screen. carefully plan on lights and minimise the green screen area may help JY |
#6 |
Kino-Eye
David Tames { blog: http://Kino-Eye.com twitter: @cinemakinoeye } |
